Thanks bluegrass. I did not word that right. I know I need RG6 cable but wasen't sure about the ground wire on the cable. Yes I will be driving in a ground rod for the dish. So all I need is the standard RG6 cable without the ground wire or supporting wire?
You don't want to drive a rod into the ground separate from the ground for the electrical entrance. You want to tie the dish and coax with a ground block to the main entrance ground. Check with a licensed electrician. There's good advice on this subject on D* own forums.
Dana
A better ground point is the water main. Most codes say you must connect within 5 feet of where it comes into the house.
You can run a separate ground wire from the dish to a suitable ground source if you don't have the coax with the messenger wire. Not the preferred method but it does work. More for static discharge than anything but it does help. Lightning does weird things. Went to a SC about 2 months ago, 18" round ODU took a direct hit, i mean it blew a baseball size hole right through the reflector, cooked one side of the dual line, cooked the 3x4 switch, switch was ground to something in the crawlspace I forget what. Now check this: Every reciever in the house survived, as did the LNB, and blew one TV up. I was like w...t...f... LOL ^^
Ahh the power of nature.
Path of least resistance. It's amazing the stories you here about lighting strikes. When I was younger I had a cb base antenna that was hit at the top and it peeled it like a banana. I had the coax discontented and laying outside on a fence that went from our house to our neighbors. It followed the fence and blew a hole in my neighbor's electrical box.
I forgot to asked one other thing. Does d** use standard shield RG6 or quad shield RG6? I won't be putting ends on the cable after I run them and want to know if installers carry either type connectors.
