this is how i was seeing russia today this morning on 97, that feed i found on what i thought was 83 was stable but then i moved to 103 and got this same thing on a golf feed.... 105 was getting steady on macys radio. WHAT THE HECK IS GOING ON?
You know, sometimes a person can spend too much time over-analyzing things....
Set and aim your dish.
Use GOOD cable all the way into the house.
Hook it to your tv with a good cable, using a proper input.
Watch tv...
Multimeter:
Use VDC setting (just like with a car)
Auto or the 20 or 50vdc scale
Red probe to center of coax
Black probe to connector
Vertical TP = 13vdc +/- 10%
Horizontal TP = 18vdc +/- 10%
that tree is on the edge of 103, 97 at the top im pretty sure it clears it, 83 is not, same symptoms in all cases. will double check with dishpointer ar.
