GEOSATpro Scans, But No Channels
$905.00
Diamond Jim
4,448
559
The Boilermaker State (#19)
I decided it was time to scan in the new PBS location at AMC21 12180-30000-Vertical-S2. Everything went fine until the video froze. I did a forced re-boot and it cleared the video, but the channels were gone. I went back into my TP list and 12180 was still there. When I go to advanced scan it shows a 100% signal, I scan the TP, it locks, but when the scan is finished there are no channels listed when it ask if they are to be saved. I have re-booted several times, deleted the TPs and re-entered them all with the same results. I have gone to other satellites and scanned in some channels with no problems there. I have done everything except a data reset, which I try to avoid because every time I do one it turns into a disaster. Any ideas on what the problem is and how to cure it will be appreciated. Thanks, ~J~
Experiencing the same problem. Don't know what is going on, but for the last week and a half or so, a scan of the transponder does not give the channels. I have had them scanned in for quite a while, so still have them, but only noticed the problem after I had deleted the channels/transponder to do a re-scan (channels had been taking a bit of time to show up, so thought that may be a slight frequency shift might help). Of course, re-loaded in a saved channel list, so have them again, but they do not show up in the Advance scan PID area of that transponder.
Anyhow, a manual entry should help. Unfortunately, I don't know what the PMT PIDs should be (hopefully someone else can give them to you) but for now just use a random number for each.
Each one is H264 and AC3, and the PCR is the same as the VPID:
HD01 East, SID:3 V:49 A:52
HD02 West, SID:4 V:65 A:68
HD03 Feeds, SID:5 V:81 A:84
SD01 Feeds, SID:11 V:177 A:180
SD02 Create, SID:12 V:193 A:196
SD03 VME, SID:13 V:209 A:212
SD04 World, SID:14 V:225 A:228
Thanks Keith, but now that is the least of my worries. I think you helped me out with this problem before. If you did, I hope you can bail me out again.
Well, I knew that if I did a data reset it would be a disaster, it was. When I re-enter the channel list from the USB only three of the 59 channels show up, the rest are dark and not showing any SRs. I've had this happen before and I cleared it up, but unfortunately I don't remember how I did it.
UPDATE: Figured out this problem. When I do a data reset the video output has to be on component. I had it on HDMI, when I switched to component all of the channels and SRs came back. I am writing it down this time. ____________________________________
Thanks for finding that old post. I am not sure what happened today is what happened then or if changing the video output would have brought them then. Thanks again.
GEOSATpro Micro HD crashed
GEOSATpro Micro Hd losing channel positions
