Scranton /Wilkes Barre Local Problem ???
Hemi 6.1
On Vacation
12,056
Wayne County,Pa
I'm having some drop outs and some picture freeze,from time to time on channel Wnep 16 HD. Can someone tell me what satellite and transponder this channel is on ,so I can check my signal strength. Or also so if anyone else is having this problem. Fox 56 is fine! Any help would be great.
I don't think there's a reliable listing of which HD LIL is on which TP, but a trick I have discovered is this:
Tune your HR20 to a HD LIL channel, then key in another HD LIL - this will put both sat tuners on HD LIL channels. Now hold Info for 3 seconds until the system info screen comes up. Then run a system test. In the system test, you'll see the signal strength for each sat tuner (and each OTA tuner). This won't show you which TP, but at least you can get a signal strength reading for the TP that your HD LIL come from. Note: you cannot record while running a system test.
Just another update, I called WNEP and they said they have a Transmitter problem,thats very expensive,and it will be fixed as soon as possible.
Directv allowing CBS and NBC HD ,for Scranton.....
D* Protection Plan---Not Free for 12/mos After All
