I am in the process of setting up my 1.2M GeoSat Pro dish on a Premium HD 2000 motor. I am trying to figure out if I am on the right track to setting my elevation correctly. According to the book that came with the motor, I should set my latitude at my latitude which is roughly 34N, so I did that. Then the way I read it, I should set my dish elevation at 29.5, I had to set it at 34 to get to 29.5 because according to the GeoSat Pro instructions, because I had to reverse my bracket for it to work on a motorized dish, I should subtract 4.5 from the displayed elevation. Anyway, after I did this, I went and got a long level and went across the face of the dish, from side to side, and put my inclinometer on it, it measured about 20 degrees. I thought that it needed to be at about the same as my latitude, which would be 34? I tried to set it as close to 34 as I could. I have some work to do, because it is only at about 30 according to the inclinometer. Your help and suggestions will be appreciated. Thanks
