SG9120 Problem
Mikey11
858
16
canada
i am mounting my new SG9120 motor on a 39 inch dish which is no problem.....the problem im having is where the coax connects to the motor.....the wires come out of the motor right where the bolts are for the dish.....it looks like the wires will be in the way when the dish turns.....it almost seems like i need a 90 degree coax fitting.....any other solutions to this???
I had the same issue with the SG2100 so I cut the dishes mounting bolts and used tie wraps to hold the wires back. I am using the same setup with the SG9120.
Yeah, that's an issue. I used 90 degree fittings plus I cut those bolts back.
thanks for the pics.....seems like a poor design to me.....i guess i will go with the 90 degree adapters.....
Any Mexican Channels
Need some help with lnb
