It would work if the range of the OTA is 55mhz to 575 like it says in the chart for the reserved space. Any channels live there?
If I recall correctly, you'd be safe for the VHF range and UHF up to about channel 20-25 or so. Most markets have multiple, maybe most channels above that. Remember that what was your old VHF "Channel 5" pre-digital is likely now being transmitted on a higher UHF OTA frequency and being "mapped" to 5 by the receiver.
Remember that the OTA channel that your TV or receiver tunes is the virtual channel, not the real channel frequency. There could be low-numbered channels in your area that are actually high-numbered real channel frequencies. For instance in my area, channe 4.1 is actually broadcast on channel frequency 42, and 17.1 virtual is 34 real. Check tvfool.com for your specific area.Channels 31 and below are in that 55-575 mHz range. In my market that would leave out FOX, NBC, ION, and some independents.
If your market has any signals higher then 575Mhz you will muck up your moca unless you install filters and with all that work your better off doing it another way other then a combiner.
That's exactly what I'm referring to...digital ATSC OTA channel signals.Thanks, but I WAS talking about digital (transmission) channels. I didn't make that clear, admittedly.
I had a 2H/0J system installed last Friday and we were able to successfully diplex the OTA on the lines to both Hoppers. We just have the OTA hooked directly to the TVs until support for the Hoppers comes out.
3HaloODST said:Does MoCA between the Hoppers work (sharing recordings?) The general consensus has been that diplexing OTA kills MoCA in most (if not all) cases... Also are you diplexing BEFORE or AFTER the node (between the dish and the node or between a Hopper and the node?)
