static bulid up?
pickone4me
299
20
wisconsin
My setup seems to work intermittently (seems to work after disconnecting, or shutting off the reciver for a while), I have diplexers to run an over the air antenna and fta over a single line. It worked fine up until a week ago maybe. Or is it luken tinkering around? I hope they don't pull 83w.
This may be a thermal failure if it works for a short time and stops until reset. Could be the power supply or the LNB getting warmed up.
You might trying checking the voltage on the coax at the LNB output.
Could be the receiver. Openbox S series has(had) a bad part that would cause issues as this. (What receiver there??)
If possible, monitor the LNB voltage (inline) with the system operating. See if it drops.
I put two 'F" barrels on a small aluminum box. piece of bare wire connecting the two. Voltmeter+ to it and - to the box.
FWIW - The future of that on 83 doesn't sound good.
SL1PLL vs Generic LNBF comparison
Dups on both polarities
