Titan?
mastermesh
1,987
Got a free account on titantv.com - now how the heck do I set it up to enter the fta stations? It seems like it wants to ask for your zip code. How do you figure out which zips to enter for the fta channels?
It took me a while to setup TitanTV. I basically fudged my address and zip code, then customized it. I have one for my local channels (digital and analog) and one called G10R. I added the call signs based on what my Fortec receiver lists for channels. I made up the channel numbers, as the call sign wasn't dependant on it being accurate. It took a while, plus I hid the bogus analog channels based on my made-up address. (some basic trial & error)
TitanTV allows for three profiles, I have two setup. One for local and one for G10.
I essentially put it all on my own zip by applying the locals and then running the customization by simply continuing to add call signs of the various fta stations I watch.
SD
KEGS use to be a Spanish channel and it hasnt been updated.
What I did was use where I use to live (Duluth) and say "antenna only" (Duluth only has 5 TV stations so it was easy...I still had Dish through them) and just click on add stations. Add the callsign and a channel number. Some people use what channel it is in their receiver. I use the legit channel and found what channel it is via here
http://www.global-cm.net/MPEGlistKuBandUS.html
see attached screenshots
Gary Z said:
What call sign do I enter to get the KEGS guide?
Titan doesn't have a schedule for KEGS. Stupidly, if you set up a local OTA guide for here in the Las Vegas area it shows KEGS on it but with a blank program guide. It won't let you add it's id (KEGSLP) to a satellite profile.
The problem with KDEV is that is what KKTU is now
KKTU 33 (ABC station) is now KDEV (but Titan accepts either callsign)
KDEV-LP 39 (RTN) is still KDEV-LP but Titan doesn't recognize it
ok got the call sign thing figured out...
but am still having trouble finding some channels...What's the true call signs for:
G10R:
Daystar
KCBU
KDEV
KQUP
KWBF
KWFT
KWWF
KYPX
WGMU
WMQF
WPXS
AMC5:
KUEN
NYN1
NYN2
NYN9
AMC4:
KUILTVFOX64 (I'm guessing FOXDT-W)
T5:
GNF Movies
TBN
There's others that don't look like they have call signs, but those are the main ones I'm interested in getting schedules on. I think some of them are WB, so should I just look for WB?
see attached...here are mine and how its set up. Some channels you wont need to add
KEYC is one of my "locals"
WVGN, WVXF, WPRU & WJSP are the C-Band nets I can get
ONN is Ohio News Network :)
KPBI is scrambled but I havent removed it yet
Just entering wpxs and the others
I get an error that say
No Matching Stations were found. Please try another callsign
under tv listings->customize channel lineups->customize digital lineup
DOH... got it working - had to add satelite, cable and ota options...
yep.
Thanks. You just have to make sure that you have the satellite (and maybe others? - I picked them all) options on. I didn't have enough options checked. I just turned them all on, hid them all, and then started manually entering locals and fta channels... Piece of cake once you can actually open up your selections to get the right stuff to select from.
