Sounds like you got the dual LNBF. One F connection is for horizontal polarized signals and the other for vertical polarization. You'll need 2 coax cables and a diseqc switch to select which one you want to go to the receiver. I believe you can use just one of the F connectors for both polarizations and have the receiver select which polarization you want to receive - you won't need the diseqc switch and one coax cable for that config. I hope that's clear.I have a titanium lnb, but don't have the wiring diagram for it. There are two connectors on the lnb how do they hook up?
I currently have a c/ku lnbf but am having receiving problems on a couple of transmitters. My receiver selects the satellite and horizontal or vertical. I guess I'll try to connect both connections with a diseqc switch.Sounds like you got the dual LNBF. One F connection is for horizontal polarized signals and the other for vertical polarization. You'll need 2 coax cables and a diseqc switch to select which one you want to go to the receiver. I believe you can use just one of the F connectors for both polarizations and have the receiver select which polarization you want to receive - you won't need the diseqc switch and one coax cable for that config. I hope that's clear.
Exactly which LNBF do you have? I had assumed that you have a dual C-band output on your LNBF so are you using a C/Ku combo LNBF instead?I currently have a c/ku lnbf but am having receiving problems on a couple of transmitters. My receiver selects the satellite and horizontal or vertical. I guess I'll try to connect both connections with a diseqc switch.
I can't remember the model, but it has a built in switch to go between C and Ku. I connected two wires to the titanium and a diseqc, and the connection wire to the house. I had it on a channel before I switched it, and tuned it in as best I could. Then when I tried changing channels, the signal went away, and I could not get a signal on any satellite except when the dish was moving. Then I rescanned the satellite and I got channels, but not all of them. The signal seems strong, so I hope the interference has gone away.Please post a photo of the LNBF or the model. If it is an old CK1 model, yes, you need either a DiSEqC or 22 KHz switch for the STB to select between the C-band and the KU-band outputs.
A CK1 does not have any interference filtering and will have problems with 5G interference on the C-band frequencies, if 5G is in use in your area.. This may be why you're having problems receiving certain transponders.
No I am saying that the lnbf that I am replacing had the built in switch. Th Titanium has 2 connections.The Titanium Satellite CK1 C/KU LNBF never had a built-in band selection switch. If your LNBF has an internal switch, it is another brand. Best to identify what you have or we are playing a game of blindfolded "pin the tail on the donkey"...
Here is the CK1S install PDF. https://titaniumsatellite.com/downloads/Guides/CK1S_LNBF_Install_Guide.pdf
