Traxis 4550 problem
qnguyen
Hi, I have a traxis dbs4550 and have problem with it. The power light and lock light are blinking. I could not power it on. Any sugesstion?
Change the capacitors from the power supply and the Traxis will work again
Saludos
Hiebert
You can determine if it is bad capacitors in the power supply, by reading all the tell tale signs in this other thread by Linuxman:
http://www.satelliteguys.us/free-air-fta-discussion/108266-broken-pansat-3500-a.html
If the unit is out of warranty (or warranty repair is too expensive), you might follow the suggestions found there.
Of course, if you don't have the same symptoms and signs, then maybe it's something else.
Have you tried to load new firmware to it recently.?.
New to the FTA sat. scene
Fortec Star Classic NA vs. CaptiveWorks 600S Premium
