TSReader - new version adds USALS
digiblur
14,190
4
Louisiana
Version 2.7, build 45b:
* All: Fixed a crash with DCII muxes with very long service names.
* All: Added support for the Nextorm DVB-S2101 USB interface. This is the "new" DVBWorld DVB-S/DSS tuner - looks identical to the DVBWorld tuner but needs a different source module because of differences in the hardware. If you can't get the DVBWorld source module to lock, try using this one instead.
* Std/Pro: Added support for USALS positioners.
* Std/Pro: Added the -PU command line option to allow the USALS position to be set from the command-line.
* Pro: Added thumbnail decoding for VC-1 video streams.
* All: Added a source module to read from HTTP servers. Currently there's no rate control so it should only be used with "live" HTTP servers like VLC's.
* All: The UDP Multicast sources now support IGMP v3 add/drop membership messages on XP and above. To use IGMPv3, specify the multicast source in dotted notation, @-sign, and then the multicast address. For example 10.10.10.4@225.0.0.1.
* Pro: Fixed a bug in the thumbnail generator where ES data from the incorrect channel would sometimes get included when running parallel thumbnail decoders.
* Std/Pro: Fixed a bug in retuning from the EPG Grid on some devices.
* Std/Pro: TSReader can now export satellite INI files from the NIT by right clicking on the root NIT entry in the tree-view.
* All: Added support for DVB-S2 TechnoTrend Budget cards and USB2 interfaces. You must use the TechnoTrend standard drivers and not their BDA drivers.
* Std/Pro: Added a menu item to refresh the thumbnails immediately. Very useful if you have the thumbnail rate set to zero (so you just get thumbnails when TSReader starts) and you want to update them without restarting the source. This function can also be accessed by the F5 key.
* All: Improvements to the DVB-T BDA source module.
* All: Added three new bandplans for DVB-T scanning. These run from 118-858 MHz stepping at 1 MHz either as 7, 8 or 7/8 MHz bandwidth. Scanning this way will take a long time but will find carriers not adering to any particular real bandplan.
Version 2.7, build 45a:
* All: Fixed a crash with very long formatting strings for split filenames.
* All: Fixed the MD API to correctly set the teletext PID.
* All: New source module - FileContinuous. This is designed to work with transport stream files that are in the process of being recorded. When using this source, the rate controlled option must be turned off. Unlike the normal file sources, when this one hits end of file, it keeps trying to read the file (that's being made larger all the time) until it gets end of file for five seconds.
* Pro: Stream Monitor now uses local time throughout. Previously there was a mixture of local time and UTC.
* Pro: -N switch to automatically start the stream monitor.
Which is better
Applied Instruments
