TSreader, updated to 2.8 build 46b
vfrjim
635
Rhode Island
* Std/Pro: XML export now correctly closes the MUXRATE-BPS item.
* All: Updated the DVB-S2 FEC selection to reflect the latest DVB-S2 spec.
* All: Fixed issue with multiple Dektec USB interfaces.
* All: Fixed issue with CI-CAMs only receiving channel change messages if there were plugins loaded.
* Std/Pro: Added a new switch (-Eb) to support the EEPG on Bell ExpressVu in Canada.
* Std/Pro: Fixed an issue where certain command-line parameters could lead to source modules being passed an invalid command-line.
* Pro: Added some new functions to the Closed-Caption decoder. The M key allows masking of multiple CC streams and the L key toggles logging of raw user data and extracted EIA-608 and EIA-708 to a text file.
* All: The USALS positioner code has been re-written and now includes buttons for east/west, north/south which makes it much easier to setup and use. This means the -PU command-line switch has changed since it now requires an east/west indicator. See the command-line documentation for the latest.
* Std/Pro: Fixed an issue with the -u switch not selecting teletext subtitle streams on Australian DVB-T.
* All: Item counts for the DVB EIT, NIT, SDT and BAT tables are now displayed in the tree-view.
* Std/Pro: Corrected a problem with the -u option not recording all teletext/subtitle streams.
* Std: The faster and more robust H.264 decoder from TSReader Professional is now included with TSReader Standard.
* Std/Pro: After recording with a time limit, the next record session resets the recording time back to its original value rather than zero.
* Std/Pro: If an automatic (command-line) recording is started and the program to be recorded doesn't exist in the mux, TSReader now displays a warning dialog.
* Std/Pro: In the EPG grid when scheduling tasks its now possible to change the recorded program number via a translation file - look at the FAQ for details (look for EPGMAP.INI).
* All: Fixed a bug where a recording made from a stream that included extra data streams (such as teletext) would cause continuity errors in the recording if the PID of such streams was 0x0020.
* All: The DVB-T BDA source module now works with devices like the AF9015-based demods that have no receiver component. Thanks to Christian Zietz for the fixes.
* All: Experimental DVB-C BDA source module.
* Std/Pro: XML export now includes audio sample data when the audio thumbnails are enabled. This is useful to automatically check for silence. Look for the <AUDIO-SAMPLES-CHANNEL-1> in the XML.
* Std/Pro: A decoder for AAC audio is now included with TSReader. This parses and produces thumbnails for MPEG-2 and MPEG-4 AAC streams.
* All: Added a source module for the Sencore DTU-235 DVB-T analyzer.
* Pro: TSReader Pro now includes a signal/GPS position logger that writes data into a comma-seperated file for importing into mapping software. GPS receivers with NMEA protocol are supported including serial and Bluetooth devices.
This if for TSReader and I am not sure if the "lite" version was updated.
TSReader Update & Support Portal
For Valentines Day, Ten Reasons Why Satellite Dishes are Better than Women
3abn/Geosat Pro 90 cm dish Owners...SOUND OFF!
