Tuner Tests Showing Different %'s
trainerman
4
Missouri
Does it mean anything when I run the info and tests on the setup page that tuner one is acquired at the mid-90's and and tuner two is always much lower...in the mid-70's or 80's? Does this indicate a problem of some sort?
if it's much much lower then it could be a bbc problem. but it's pretty normal for one tuner to show different numbers than the other. this fluctuates.
You get ota fluctuations with your tv's regular digital tuner. that has nothing to do with a bbc. you can get major sat signal loss if a bbc goes bad.
