2 2002tii Member Original poster Apr 13, 2010 11 0 wv Nov 30, 2010 #1 Is there away in the new TV2 mode to use composite cables to the second tv with a short run?
H hawker152 SatelliteGuys Pro Nov 8, 2009 357 0 Kansas Nov 30, 2010 #2 Yes. Not sure what the question is. You run cables from the 922 to ur tv2
2 2002tii Member Original poster Apr 13, 2010 11 0 wv Nov 30, 2010 #3 hawker152 said: Yes. Not sure what the question is. You run cables from the 922 to ur tv2 Click to expand... Hawker I didn't want to use coaxial with my setup and wanted to confirm if composite cables would work?
H hahler2 SatelliteGuys Pro Jan 14, 2005 457 84 Ashton, SD Dec 1, 2010 #4 You can use composite cables. However I don't think you will be able to watch tv2 then. It will just mirror tv1. Not 100% on that but I'm pretty sure tv2 is only over coax.
H hawker152 SatelliteGuys Pro Nov 8, 2009 357 0 Kansas Dec 1, 2010 #5 2002tii said: Hawker I didn't want to use coaxial with my setup and wanted to confirm if composite cables would work? Click to expand... I never said use coax. PLEASE LOG IN TO GET RID OF THESE ADS!
lakebum431 Pub Member / Supporter Pub Member / Supporter Lifetime Supporter Sep 5, 2005 17,314 5,372 Norris, TN Dec 1, 2010 #6 You can use composite cables for TV 2 as there is a specific TV2 composite out. See here http://www.dishnetwork.com/downloads/product_brochures/922_Brochure.pdf I haven't tried this and don't know how much better (if at all) the picture is over coax though.
towboy123 SatelliteGuys Guru Nov 30, 2010 129 0 FSM In Raleigh Dec 1, 2010 #7 It works as expected to use composite cables for TV2 when using the TV2 ports
