Two OTA Antennas
Pi314
153
12
WI
I'm setting up an OTA antenna for a neighbor.
HD bowtie antenna on the roof - almost all locals come in except for two channels.
HD bowtie antenna on ground floor - only the two channels I'm missing from roof come in.
Can I combine both antennas into one coax line? Sort of like using a splitter in reverse?
If each of the antennas do not receive same channels, could use a splitter backwards. But this will introduce a 3db loss on all the channels.
Try it. That's all that can be done.
If both antennas receive ch 'y' using a splitter could knock it out completely. Try it again with one coax shortened 1/4 wave x velocity factor @ the frequency of the channel.
Think I'd first try with one antenna, moving it about to find the 'sweet spot' where it gets all channels.
More detail may be had if we had your TVFOOL report and the particular channels you get on which antenna.
Antenna selection, and installation, is science with a lot of art.
Very rarely does science win hands down. Many times art is the victor.
Thanks FaT Air, as a last resort I can put in a coax A/B switch. TV Fool info is as follows:
The two channels I do not get on the roof are 3.1 and 47.1 but can get them on ground level without all the other channels.
Have you tried moving the antenna on the roof around.
It could be in a null spot for those 2 channels.
If the rooftop antenna is amplified that is the problem overload.
It's SOS for Soul of the South
I cut the cord
