Uplink Activity for the week of Monday April 10th Echo X Month :)
Happy Early morning activity....
And Congrats to Echostar and Dish Network for a Successful Launch and Delivery of Echostar X!!!!!
Here is your SPECIAL ECHOSTAR X UPLINK REPORT :)
Echostar 110 :)
9310 (WATE) Went Live on SPTBM TP Frequency: 12.384 GHz TP 12 Moved from beam 212 To beam 2582 Same Freq.
9311 (WVLT) Went Live on SPTBM TP Frequency: 12.384 GHz TP 12 Moved from beam 212 To beam 2582 Same Freq.
9312 (WBIR) Went Live on SPTBM TP Frequency: 12.384 GHz TP 12 Moved from beam 212 To beam 2582 Same Freq.
9313 (WTNZ) Went Live on SPTBM TP Frequency: 12.384 GHz TP 12 Moved from beam 212 To beam 2582 Same Freq.
9314 (WBXX) Went Live on SPTBM TP Frequency: 12.384 GHz TP 12 Moved from beam 212 To beam 2582 Same Freq.
9316 (WKOP) Went Live on SPTBM TP Frequency: 12.384 GHz TP 12 Moved from beam 212 To beam 2582 Same Freq.
9318 (WVLR) Went Live on SPTBM TP Frequency: 12.384 GHz TP 12 Moved from beam 212 To beam 2582 Same Freq.
9030 (KTNV) Moved From TP Frequency: 12.239 GHz TP 2 TO TP Frequency: 12.384 GHz TP 12
9031 (KLAS) Moved From TP Frequency: 12.239 GHz TP 2 TO TP Frequency: 12.384 GHz TP 12
9032 (KVBC) Moved From TP Frequency: 12.239 GHz TP 2 TO TP Frequency: 12.384 GHz TP 12
9033 (KVVU) Moved From TP Frequency: 12.239 GHz TP 2 TO TP Frequency: 12.384 GHz TP 12
9034 (KVWB) Moved From TP Frequency: 12.239 GHz TP 2 TO TP Frequency: 12.384 GHz TP 12
9036 (KLVX) Moved From TP Frequency: 12.239 GHz TP 2 TO TP Frequency: 12.384 GHz TP 12
9037 (KINC) Moved From TP Frequency: 12.239 GHz TP 2 TO TP Frequency: 12.384 GHz TP 12
9038 (KBLR) Moved From TP Frequency: 12.472 GHz TP 18 TO TP Frequency: 12.384 GHz TP 12
9039 (KFBT) Moved From TP Frequency: 12.239 GHz TP 2 TO TP Frequency: 12.384 GHz TP 12
7350 (WEAR) Moved From Echostar 105 TP 22 Frequency: 12.140 GHz TO Echo X TP Frequency: 12.384 GHz TP 12
7351 (WKRG) Moved From Echostar 105 TP 22 Frequency: 12.140 GHz TO Echo X TP Frequency: 12.384 GHz TP 12
7352 (WPMI) Moved From Echostar 105 TP 22 Frequency: 12.140 GHz TO Echo X TP Frequency: 12.384 GHz TP 12
7353 (WALA) Moved From Echostar 105 TP 22 Frequency: 12.140 GHz TO Echo X TP Frequency: 12.384 GHz TP 12
7354 (WBPG) Moved From Echostar 105 TP 22 Frequency: 12.140 GHz TO Echo X TP Frequency: 12.384 GHz TP 12
7355 (WJTC) Moved From Echostar 105 TP 22 Frequency: 12.140 GHz TO Echo X TP Frequency: 12.384 GHz TP 12
7357 (WSRE) Moved From Echostar 105 TP 24 Frequency: 12.180 GHz TO Echo X TP Frequency: 12.284 TP 12
7358 (WHBR) Moved From Echostar 105 TP 22 Frequency: 12.140 GHz TO Echo X TP Frequency: 12.384 GHz TP 12
7220 (KSPR) Went Live on SPTBM TP Frequency: 12.384 GHz TP 12 Moved from beam 212 To beam 2482 Same Freq.
7221 (KOLR) Went Live on SPTBM TP Frequency: 12.384 GHz TP 12 Moved from beam 212 To beam 2482 Same Freq.
7222 (KYTV) Went Live on SPTBM TP Frequency: 12.384 GHz TP 12 Moved from beam 212 To beam 2482 Same Freq.
7223 (KSFX) Went Live on SPTBM TP Frequency: 12.384 GHz TP 12 Moved from beam 212 To beam 2482 Same Freq.
7224 (KWBM) Went Live on SPTBM TP Frequency: 12.384 GHz TP 12 Moved from beam 212 To beam 2482 Same Freq.
7225 (KDL) Went Live on SPTBM TP Frequency: 12.384 GHz TP 12 Moved from beam 212 To beam 2482 Same Freq.
7226 (KOZK) Moved From Frequency: 12.443 GHz TP 16 TO TP Frequency: 12.384 GHz TP 12
I will be reporting through out the month on the Echo X uplinks as well as the normal uplink's on wed... so Keep tuned for your city as it will be happening soon :) Off to bed I go :) and a long month it will be :)
TP2 on E8 is spotbeam...my locals are on there (well part of them...Duluth, MN)
E8 has spotbeams at 2, 4, 6, 8, 10
Freed up ConUS capacity is likely to be minimal as EchoStar 10 uses more than EchoStar 8 in the Spotbeam category. There will be new Spotbeam Tp numbers to replace the old ones except in the case of Tp 4 which is used by both for Spotbeams.
John Kotches said:
Bob,
Is there any way to show a Transponder map as these moves occur? It would be interesting to see how many Conus TPs free up.
John im going to work on that later on next month after all the moves accour.. but you will likely see a pratically a hole bird free up and some tp space on 119 :)
Looking through the lyngsat lists, it appears most of the CONUS locals on 110 will be replaced by spotbeams on those same transponder frequencies, so no CONUS gain there. The only locals on 119 that are CONUS are NYC, LA, and Denver, which must remain CONUS, so no gain there either.
Most of the freed up transponder space will be from 61.5 and 105 :). Remember, theres ~20 TPs of locals on 105 that are moving over to 110.
Kirby Baker said:
Is E* keeping 105 though? I thought it was going away along with 121, i.e. no more superdish?
Echostar owns 121 and has a long term lease on 105. They are just moving the standard definition locals off those satellites. They have not said what they are going to use those satellites for in the future.
So if I am understanding you correctly you are saying that even after EX is fully operational we wont gain any additional CONUS coverage?
HD Lil you mean, he's talking about National.
And right now they have room for 3 more MPEG2 channels at 61.5 &129 before they switch to MPEG4 and get more on a TP
Paradox-SJ said:
With this being the case, were would they put any new national HD channels?
I'm guessing they'll eventually go on the FSS slot at 118.7, requiring yet another dish upgrade.
