It is technically better to routinely set it at native or 1080i ? I am using component cables. Thanks
It's not just Mitsubishi. Most of the CRT-based RPTVs on the market do not support 720p. 720p requires the highest scan rate (in lines per second) among all resolutions (higher than 1080i) and most of CRTs simply can't work that fast. Some of these RPTVs (if you are lucky) will convert it to 1080i, others will down-convert it or simply refuse to work...tscallions said:I've got a 65" Mitsubishi HDTV as well. What's up with no 720p support from Mitsubishi?
