VS 2000 Extreme Question
farb
Feb 24, 2006
11
I just bought one and it will absolutely not pick up anything in any scan except blind scan. If anyone has any info I would appreciate it.
please read this post first
http://www.satelliteguys.us/showthread.php?t=38974
With a lot of newbies getting systems and needing help setting up, please help us out when creating posts (this goes for the veterans too)
If you are having trouble with your setup,
PLEASE PLEASE PLEASE PLEASE list your setup (what receiver, LNB, dish size and motor if applicable you are using).
If you are asking “my numbers are 36 elevation, 177 azimuth and -20 skew…is this right?” Please post location (city & state or zip code)
Many posts the first response is “what are you using for equipment” or some posts don’t get answered because it’s too vague. The more info you give, the better we can help out….
We can’t read minds
Thanks for your understanding….
-Berg
I only use blind scan
I only haved used blind scan, but will try channel scan later this evening...will post results...Which firmware are you using....new firmware was posted on their homepage (viewsatsa) you know the rest of the URL.
jeff
jeff
Thanks Jeff. The reason I did not post system information is because my system is working fine. The blind scan gets me everything. All of the others cans get nothing.
Fixed It.
I was not inputing the correct details for my LNB. Now it works fine. The new frimware also properly identifies the networks on Galaxy 10R.
