Weak Transponder on IA5?
mrtrance
46
I have the coolsat5K pointing at IA5. I wanted to try to get the highest quality on the weakest transponder in order to maybe fix the pixelation issue I've been having on some of the channels. I want to go through the transponders on that sat and adjust my az/elev/lnb to get the highest quality on the weakest transponder. Does anyone know how I can do this using the coolsat5k?
Yeah , keep an eye on the quality bar and play with your dish, no fast movements and give the bar a few seconds to get an accurate reading.
1st find the channel that you have pixelation issues with, look at the frequency of that channel or channels and find the manual scan or motorized setup, then toggle thru the frequencies till you find your problem frequency and make the fine adjustments.
What channels come in crappy, this might be normal cause I've seen many channels with this problem, Amazonas has a couple of channels where the compression is such that you can compare it with grainy video or low quality digital recording.
The question is, are the channels pixelized or are you getting tiling which occurs with weak signal strength or when it rains ?
It won't help with pixelation, but the weakest transponder for me is 11874H. I usually have to nudge it in, but it will hold at 49%, which is enough for me.
Ariza Dish Manufacturers Elevation Problem
Woo Hoo! It's all about timing.
