Hello -- can someone let me know if I can see (no pun intended) a clean line of sight... what deg do you need to directv's bird for HD and Locals for CT?
thanks in advance,
John
thanks in advance,
John
charper1 said:PhaseIII is a 3 LNB dish for MPEG2 HD and standard SD programming.
The AT9 is a 5 LNB dish for MPEG2, MPEG4 and standard SD programming.
MPEG4 is limited to HD locals and some RSN coverage in limited metro areas, so it may not be required.
I am sure there are a few users in your area that might chime in soon and help you determine your best option based on your programming needs.
raoul5788 said:Chiming in here from Cheshire CT!![]()
The local hd sat is next to 101, which is at 233 degrees and 34 degrees elevation. Quiite honestly, I'm not sure which Spaceway the local channels are on, but it's either two degrees to the left or the right of the 101 sat. Use a compass to find 233 degrees and a protractor and level to find the correct elevation. The best place may be out in your yard, but that's actually a good thing, because a pole mount is the best way to go.
johnner1999 said:Thank you -- we started to clear a couple tree's today that are on our side of the line. It appears that d* is a better "fit" for us then E* which is at 246
Off topic -- since you are in CT and I assume you are using the local HD channels? I think we only have wvit and wfsb so far, how do they come in?
TIA
John
johnner1999 said:correct up here in the NW corner we don't much OTA (just snow - lol) and cablevision well stinks
I wanted Dishnetwork (more HD channels) but no local HD so I'm kind of confused![]()
does your dish have the 3 or 5 lnb hook-ups?
