What to expect?
Tweek!!!
CT
Hey Guys,
I move into my new house on friday and am having Voom installed on 5/3.
I've never had a satellite hookup before, always cable.
Can you explain how the installer gets the cables for a 2 room install into the house? In general do they do a pretty good job or just sloppily route the wires? I know YMMV too.
Just curious if SOP is to go to a wall plate or just drill a hole in your siding and run a bare wire leaving you to make it look pretty.
Looking for a little insight prior to the big day. Also in addition to asking for other than the stealth antenna and no diplexer, any tidbits I should keep in mind for the install?
Any and all input is appreciated.
Thanks,
wj
TweeK,
welcome. It depends who does your installs. I suggest you to speak to installer and let him know exactly what you need done and don't assume that he will do it the way you envision.
A Bad Voom disconnect story...so far
Multiplexor Question
