Windows 10/11 Download
I could probably use that as a starting point, but I don't like the full size icons. If you have to click on each folder that's also a no-go for me, it has to be cascading.
I used to have Peppermint Linux in a VM, that was about as close as I could get to recreating a Windows NT4.0 style of menu structure, but I could never get it to scale properly in VMWare on a 4K display and eventually gave up.
Whatever the boot up time it's fine with me. The longest part of my bootup is the HP SureStart BIOS integrity check. Once that is done, it's only a few more seconds. I haven't done this reg tweak yet since the reformat, but I switched the bootup animation to the Windows 10 style spinning circle of dots, and it's two and a half rotations. I can live with that.
Because it's what I prefer.
I hope you don't believe that makes it wonderful (especially when you're using workarounds for Microsoft's malfeasance).
I use LibreOffice as opposed to Microsoft office (even in Windows) because it's UI is like the Office of old, so I'm putting my money where my mouth is (in a manner of speaking). The ribbon was one of the worst ideas to come out Redmond.
I used to pin the C: drive to the Win Taskbar and it would open in cascading style
2026-10 Preview Update Builds: 26300.9818 and 26200.9818 (KB5127936) has been released. Moderate time needed for those choosing to perform a manual download/install/restart. Quality improvements only. No new operating system features.
Reactions: Tweek
Actually it looks like there are a lot of features new or updated, although most are on a gradual rollout schedule.
There were several new updates today.
That is correct. My late report is due to internet outages in my area. 2026-11 Security Update (KB5132061) Builds: 26300.9974, 26200.9974 and26100.9974 along with several .NET Security Updates were released yesterday. Moderate time needed for those choosing to perform a manual download/install/restart.
Reactions: Tweek
The Bleeping Computer front page is littered with Microsoft reports this morning. Some are happy, some are scary, and some are ridiculous.
Reactions: Tweek
KB5132061 failing to install with error 0x800f0993 seems to be somewhat common. Happened to me one out of my four computers, my main laptop.
Finally got it to install succussfully by running the following commands as admin
DISM /Online /Cleanup-Image /RestoreHealth
sfc /scannow
net stop bits
Delete the entire content of Windows\SoftwareDistribution
net start bits
Restart computer
Reactions: Tweek and Foxbat
Wow. I guess it's good that incantation still works. I would have figured that Microsoft would have come up with a better solution to patch management by now. I think I learned that back in the W2000 or XP days…
Reactions: HipKat and Tweek
I'll be running it this weekend. I had to boot into Windows the other day, and it froze after booting with a Python error. A hard reset, and it booted fine, but I've had Wiondows freeze a few times over the last few months during boot.
Those commands are something I've always kept for times like this, after I run Samsung Magician, should it not find the issue.
Reactions: Foxbat
I use a Beelink Mini PC, Intel 12th Gen Alder Lake- N95 running Windows 11 Pro as my Channels DVR. I only log into it when I need to, and do that with the Remote Desktop app from my personal Windows 10 laptop.
It runs Channels DVR, plus Docker Desktop and a few bridge programs used with Channels like that. It's supposed to auto-logon into my profile back into the Windows Desktop, and auto start all those things. EVERY TIME it reboots for whatever reason, usually only AFTER one of these push updates at 3am, Channels itself restarts fine, but my Docker Desktop and two bridge programs do NOT restart unintended like they should.
IF I then log into the Windows desktop using the Remote Desktop app, Docker and my bridge programs THEN engage and startup as they should.
What's wrong with my settings, so I can fix this once and for all to properly log into my profile after an automatic update reboot to bring up Windows and allow these programs to autostart as they should?
I don't use docker on my windows 11 pc but I do use Channels DVR and after updates it reverts back to the login screen and Channels DVR does not run until I login. I have been burned by this several times. How are you getting windows 11 to auto log in?
Apparently, I'm not, that's my problem.
The Channels DVR software can be set as a service, and that starts automatically whether anybody is logged in or not after the pc reboots. That's a choice when you first install it by checking a box. There's likely a way to bring that choice back up after it's been installed for a while, BUT, you'd have to ask them on their forum for the best way to do it as I don't remember.
Channels Community
Reactions: b4pjoe
Channels Community
I think I tried it as a service once and it would not let me use hardware transcoding and forced it to software transcoding.
Ok, I just used Google A.I. to tell me how to fix all this, so I'm all set now as that makes it all easy and step by step. I changed an admin setting in gpedit so that automatic updates will download, but will prompt me for install and reboot, they aren't allowed to automatically install and reboot at 3 am anymore. I then changed my one bridge program to start via Task Scheduler instead of its own autostart feature, so it'll log in with my Windows account after a 1 minute delay
Reactions: Foxbat and HipKat
I highly recommend running a default Memtest86 test (four passes, all tests) on the machine. Note that it may take all night.
I'll run it while I'm at work but this only happens when I boot into Windows, never Linux
Windows consumes considerably more RAM than Linux, so your chances of encountering flaky RAM with Windows are similarly higher.
It is a non-destructive test, so all you have to lose is access to the computer for the duration of the abortable test.
Reactions: HipKat
Apple Appears to be Down
178 sites spread malware unknowingly this week
