Would this work on a Zinwell 4x8?
C/ku LNBF to non 22khz side of switch
single line from fixed C band dish to 22khz side of switch.
Hank, Fat Air put a 30'' dish on the front of his bud to get ku on the same dish he had a single output ku lnb on his 30 inch dish.
I have tried multiple diseqc switches and have not got them to work. I don't know if it's something I'm doing wrong, settings a stack of bad switches xcetera.
I have three zinwell 4x8 switches. I figure I'm a put one to work
So true..Have a Enigma 2 receiver here that does not work with a Diseqc 2.0 switch.Just went through this fiasco the other day when I wanted it connected to the entire sat farm..Used a Diseqc 1.2 8x1 and a couple Diseqc 1.2 4x1`s to cascade.Hmmm?? I will admit i have had problems with some diseqc switches not working with some receivers.. You might try a different brand then the ones you have... I have soooooo many diseqc switches in my setup, I've lost count..![]()
Technically you could get signal from the three LNBFs you have connected. But only one polarity from each one. The multi-switch is designed to pass both polarities from two dual output LNBFs, selected by up to eight receivers. the 4 inputs are 18V (H) 13V (V) 18V (H) 22khz on 13V (V) 22khz on. The inputs are selected by voltage and 22khz on or off sent by the receiver. The is no DiSEqC involved with this switch. Look at the FTA FAQ section, there are a couple good threads explaining switches and DiSEqC .Would this work on a Zinwell 4x8?
What receiver are you using Hank?..What switch options in the setup menu?..What Diseqc switches have you tried?
Is there pictures of that? I'd like to see that
