OTHER X2 Premium HD PVR Satellite Receiver
madworld, which firmware is in the box you are using, that would be helpful. Generally I got about the same results as you, mine had firmware dated April23, I believe. I backed it up, and loaded the file on the website, May20 dated. I noticed the scanning slowed down a bit with that firmware, but the sound problem was still there for me. I was using the spdif jack to run my home theater amp for sound, but it would cut off the sound after about 30min. Going to hook it back up tonight and see if that setting for LL or whatever makes any difference on the audio problem, think I already had tried it but didn't note it anyplace.
HW VER 30270303,3
SW VER r2188-19194107 -xs0
DATE : Apr 9 2013, 11:10:32
Des : IX2476_S2
I correct myself- that firmware is the same as the original firmware in mine, Apr9, not apr23. I restored from backup usb tonight (late, after the hockey game!). Will try to use until the next update becomes available. Without reliable audio output though, it won't be a day-to-day use receiver.
Official latest is March 30 2013, beta unofficially released is May 20 2013. For HH motor you need to create a sat list in alpha numerical order from 45W to 139W in order for them to work properly. We expect to have this from X2 on the next USA file release
this came on the unit i bought
HW VER 30270303,3
Des : IX2476_S2
Same as I'm using, the H-H motor seems to work quickly, and I don't have all the satellites in 'arc' order either ,lol. some of them are waaay apart but it does go to them as it should, or seems to. The audio thing is the major problem, mine apparently isn't passing any AC3 signal out to the home theater amp, I've been watching it tonight and the Dolby sign never lights up on the amp. But regardless of dolby or pcm , sound cuts off after about 20min anyway. What the setting is on HDMI seems to not matter.
for h-h i left 97 at top and just named the rest in order from the remote. did forget 101 some how and it's at the bottom of list. deleted all tp's after naming them.
How about April 7th 2013?.. that came with my second unit last month that I use at my office. Isn't that official?
march 30 not 20 is r2164-17661307-xs0. I dont have a April 7 and have no idea. I'll PM you my e-mail so you can send me a copy of the database with the April 7 to take a look if you can, Thanks
Look what ups just dropped off to me. I hope I get a chance to play with it this weekend.
Actually a nice pack out. I didn't expect the wireless sdapter or Hdmi cable with the unit.
Although its the first receiver I purchased that did not come with batteries with the remote. (Or in this case remotes)
Check mail
Carlos.. its actually April 9th and it has been the best fw for my daily use.
Scott, what version software did your unit arrive with? Pro96 says Apr9 has been his best for daily use firmware, but I find it loses audio after about 20minutes of use. Changing channels brings it back, but it acts like its cutting off the spdif jack about every 20min. He may be using his with the composite cable instead of HDMI, I don't think the problem affects the red/white/yellow cable at all.
HDMI
OTHER Default Syrian Drama 97w 11898 22000 V not working?
OTHER Diseqc 1.2 motor on a budget
