multi switch sw44 to upgrade
satguysca
3
I have a 9200 HD,PVR with 2 regular rcv.With a power inserter & a multi-dish switch sw44.I would like to add 1 more rcv to my legit sub to BV.My question is my sw44 is full.Can i upgrade to 6 & with switch should i choose from.
This is what i have :21"or22" BV dish , 2 dual lnbf ,82,91
need your HELP. THANKS in ADVANCE.
SATGUYSCA :confused:
Honestly the easiest thing to do is upgrade to DishPro. Get a couple of DishPro single (or dual...hell get a Twin they're cheap) and a couple DP34 switches. The DP34 switches can be cascaded.
So it would be two lines from the dish (one from each LNB) to the DP34 and you can use 4 lines output. 2 to the 9200 and 2 to the other two receivers. The 2nd DP34 can connect and you could have up to 4 more recievers
Or get a DPP44+ switch. That would allow you to run one line to the 9200 and use a separator. Then the other 3 outputs can be for the other 3 receivers
Can i connect my sw44 output to a (4x1) Diseq input,then connect BV rcv to output on the Diseq?
Thanks for the reply ICEBERG
SATGUYSCA
nope
The only other option is to get 4 high frequency splitters and another SW44. On the 4 lines from the LNB's you put the splitters on and hook them to the 2 SW44 switches.
DishPro would be easier ;)
Well i guess i will go with Dish Pro. Now can i connect my 2 FTA to my existing BV.Also have 33"dish with 2 direct tv dual lnb with a bracket for 110/119 DN. Can you explain me this setup & what do i need to get. Where the best place to buy in ONTARIO..
THANKS ICEBERG , i realy apreciated you're help :)
SATGUYSCA
why would you wanna connect fta to bev, the only channels available are barkers so no point
this may work if ya wanna try a greymarket subscription, but as far as 110/119 with fta again no point only barkers
i suggest you stick with your provides boxes for their services
