motor trouble
drhcanada
14
I have an SG2100 motor hooked to my 36" dish and just yesterday I've been having a problem where if I got west of 110 and then say try to come back to 97, the motor goes a degree or 2 and then stops without continuing beyound to arrive at 97 etc.
I can however chose the send motor to centre command and it goes to south, but once I pass 97 it wont come back without manually going back to south.
Have tried resetting the motor and receiver and swapping the receiver for another and still the same issue.
Anyone else have any suggestions or is this a bad motor?
thanks
You could check your cable, any switches inline, take them out if yes and try it. Do you use diseqc1.2 or usals? Have you tried both? I know the newer motors with the two buttons instead of the paper clip hole are a little more difficult to re-set, sometimes I find it doesn't take and I have to do it over. From the symptons you describe I would say the motor needs to be re-set but you've already done that so maybe the motor is bad.
nothing between the receiver and motor, tone switch after the motor.
normaly use USALS but tried with diseqc1.2 as well and still it wont go back beyond a few degrees east of 110 unless I choose the go to reference or centre from the receiver.
moved the dish manually from the dish it self and it sounds and moves fine.
will try another reset tomorrow to make sure it took. its the little pin hole reset so I'll just have to do it a few times maybe to be sure.
You probably already know but just in case, make sure to kill the power after you reset the motor otherwise it doesn't re-set.
Seems weird it works ok when you give it the go to zero command, it seems it at least works mechanically ok. Did you try another cable?
thanks
Just curious. Is this a DMS version of the SG2100 by chance? Two button or one?
thanks, actually I didn't know and this fact has fixed my problem, working once again using USALS as it was before. so note to self, after pushing the reset button on the motor, hard boot the receiver. simple
The model is Moteck SG-2100 digipower motor with a single button for manual motor control. did not even realize that there is multiple versions of this unit from different companies.
