True south is 89w. Single and 10750 are the settings in the menu. If the lnb is a few degrees off skew will I still get some signal? I sat and twisted the lnb while looking at the meter but couldn't see any difference at all.
What is your Dish Elevation set at?
That's the Spirit!
By the way, are you located close to Memphis?
Offset dishes are taller than they are wide to compensate for the deflection angle of the signal (if you look at the dish from 22 degrees above it, it will appear absolutely circular). Mounting them on their side will not work, since they are not designed to properly bounce the signal to the LNB when in that configuration.
