Primestar 84E/BSC621-2 LNBF Experiment
Well, as you’ve heard “What’s old is new” I decided to see if I could get any C-Band channels on my 1 meter by .7-meter dish. After searching this site and Sadouns’ forum I found the following links, which add so much to the story.
http://www.satelliteguys.us/free-air-fta-discussion/39119-40-c-ku-band-dish.html
http://www.sadoun.net/forums/installation-support/5829-using-bsc621-2-c-ku-lnbf-3.html
http://www.satelliteguys.us/fta-mpeg2-equipment-reviews/68243-bsc621-2-c-ku-lnbf-5.html
http://www.satelliteguys.us/free-air-fta-discussion/131748-prime-star-offset-scaler-ring-cband-lnbf.html
There is interesting reading from others as well as pictures of their work with C-Band and the Primestar 84E dish.
This post puts most of it in one place to tie things together. Also I have posted photos of my own project.
After a couple days of construction and fabrication, yesterday I put the new LNBF and Holder on the dish. I had taken the old arm and LNB support to use as a pattern for the new holder. I made sure that the LNBF would be situated in the best focus of the dish. I did allow for additional adjustment for the new LNBF. Precise dish to LNBF measurements were taken and then checked against the new holder and aperture. I also made PVC pipe bushings from 1 ½” and 2” pipe. This adapted the Stab 40 mm dish tube to the 2 5/16” dish bracket. I have inverted the bracket to adapt it to the motor.
Last night I enjoyed a whole evening of C-Band programming, well worth the enjoyment I get out of this hobby. I have just started tweaking and balancing the setup. I don’t know how many channels I will get but the few strong channels I get are enjoyable. I attached some screen shots from last night.
