100cm c band dish??
Techfizzle
Banned
985
there is a website www.dishstone.com that sells ku and c band dishes including mesh, multi panel and single panel c band dishes they sell multi panel in sizes of 100, 120, 135, 150, 180, 210 and 240 cm... wait a minute:eek::eek: 3.6 foot c band dish???? i never knew they made such a thing is there any reason to have one? i wouldnt think it could pick up much.
EDIT: I sent the a email asking what it would cost and what the 180 cost too if its cheaper then sadouns 180cm i might jump on it.
C Band 100cm (3.6 feet) satellite dish antenna - 6 Panels​
See More Pictures in Gallery ...
Send An Inquiry Now​
Specifications ...Panel (Sector Divided) 6 PanelsDiameter(cm)100CMMaterialSteel Finish of reflectorPolyester Powder CoatingAvialable Mount TypePole Mount / Ground Mount Focus Length 68.4 C-BAND Gain @4.0GHz31.1dB +/- 1dB KU-BAND Gain @12.5GHz 41.15dB +/- 1dB Ambient Temperature-40oC ~ +60oCAperture Efficiency>80% Survival Wind180 km/HRelative Humidity0~100% F/D Ratio 0.38Azimute ( [FONT=Arial, Helvetica, sans-serif]o[/FONT] )0?360/0?360
I would never recommend anything under 6' for c-band. there are a select few signals you can get on c-band with a small reflector but with digital, you need the tighter beamwidth for isolation of interference from neighboring satellites.
With DVB S-2 coming up in the future, everybody had better stick to 8' to 10' for their dish size.
As HD on 8psk s-2 comes about it is going to require a cleaner signal that only a larger reflector can produce.
If you do some reading sure folks got stuff on a 1m dish, 84e Primestar dish but its few and far between...seems likie a lot of work for one or two transponders at barely above threshold
As noted above, 6 foot MINIMUM for reliable reception on C-Band
I've got a 1 meter mini set up. But like Ice points out, it's barely above threshold on Galaxy 16 for the nets.
If you've got the dish but need an LNB, they can be had for real cheap on ebay. I got one for $15 shipped just to see if it was doable. If it wasn't, so I spent $15. That's only a 1/4 tank of gas for the car.
would a 6 panel soild 6 footer do better then a winegard? i spoted a winegard 6 0r 8 foot somewhere
There are some pretty cool looking dishes on that website. The mounts appear to be designed for flat roof installations for most of the models. I bet for Ku band they would be fine.
I wish that our favorite sponsors had more dishes like those.
I'd use it for a really cool-looking prime-focus Ku dish!:cool:
