setting up fta system, need help
Randy1
38
north cAROLINA
I am setting up my longitude and latitude on my receiver.
My specs are
latitude 35.9494
longitude -82.0460
My question is latitude is north right?
And my longitude is West right?
My specs are
latitude 35.9494
longitude -82.0460
Randy,
Yes, you are right on both counts.
It is generally considered that a positive latitude means NORTH and a negative longitude means WEST.
RADAR
The equator & prime meridian distinguish the directions
We're north of the equator and west of England ;)
I have an on/button on my antenna setup entitled 0/22kHz.
Should this be on or off?
I have a invacom /quad////Polar Qph-031.
Should my setting for lnb type be lnb-10750?
Switch - "none"
input - "none"
port "1"
THanks guys for taking time for me!
Switch - "none"
input - "none"
port "1"
0/22KHz switch... If you did not install a 0/22 KHz switch then it should be set to OFF
For the LNBF (QPH-031) the LNB type should be SINGLE or STANDARD.
The frequenccy should be 10.750 if you are connected to the LINEAR side and searching any linear polarity sats. If you are searching for a circular satellite and connected to the Circular side of the LNBF, then you would want to use 11.250.
Next Great Receiver?
125 issue
