ariza 700 DOA
Techfizzle
Banned
985
i got it today, pluged it in, and the screen "rolls" i checked and it is not my Tv or cables.
what would be causing this? the guy i bought it from said it worked fine
when i turn it out i can make out "expvu" on the screen, so that means that this had hackware on it, would this be causing it?
EDIT i did a little reading and found out that if the receiver was set on pal, it would roll on a ntsc set
is there anyway to fix this less shelling out $30 for a converter?
try the a/v cables. that usually can make it so it doesnt roll as bad and you can get into the menus to change it to NTSC
i tried both a/v and coax
looks like im going to have to buy a uk tv!!
if someone owns a ariza 700 please tell me what buttons to press to get into the menu and what to press to change it to ntsc
Also try the green component output to your composite input. Should get a B&W signal there, though probably PAL as well, but worth checking if your firmware load didn't resolve it already.
It says here that the Ariza 700PAL/NTSC conversion is automatic..........Good luck.
hxxp://www.impaktproducts.com/Ariza-700-FTA-Receiver-p-16337.html
this is how i fixed it, and this is hoe you can fix it if you ever break it
i took an old black and white tv, with the adjustable vertical and horizontal holds. then i played with them untill the picture came in ! it works now
so it wasnt broken, it just the guy that sold it did that and wanted to get somethimng out of it, unless he was using a pal set
when did that get changed and why?
i must say the ariza 700 is the smallest receiver i have seen. the only thing i dont like about it is no componet out and slow blindscan.
You can do it with a color tv too, its just a lot harder to read the menu. I have an older box that does that sometimes on its own, and its dang hard to see , but simple to fix. Ariza apparently slid off the radar, couldnt find a website except one that now only sells lnbs and brackets, meters and other related stuff. That one came out in 2006 I think.....
How would she when she would be working on something else hahahaha :)
if anyone on here watches aqua teen hungerforce, a good sitcom btw. that reminds me of the time when a hoe came over from the power company
NFL Fans (Out of your teams zone)
GALAXY 18 TRANSPONDERS CHANGED?
