Anyone happen to know what kind of LNB this might be? It is just something they want me to take down and get rid of for them. but I have no idea what it might be good for. Probably not good for anything I want to do on FTA
My Gilat said it had a Noise figure of 0.6dBOk finally took the dish down todayIt is a Channel Master 3041221 dish middle mount and has a fine adjustment for elevation. Seems to be a nice dish. Saw the tread about putting a motor on this part number. That is why i mentioned it is mounted in the middle not the lower part.
Has a Gilat LN139100 LNB on it. did some google searches but have not found much on this yet. I will try to post some pics now that it is down tomorrow. Any one have any ideas on the specs for this LNB or where to find them?
Chuck
PS. It was RG-11 cable not able to save it as I could not get in touch with anyone to let me into the building![]()
OK...what you have there is a DirecPC/Direcway dish
The LNB will work fine for KU Band...the transmitter is useless. Thats the thing underneath the arm. The LNB is **usually** both polarities but may only be one. You'd have to look
The 2nd pic shows the back of the dish with the elevation screw which is easier to slightly change elevation than a normal dish. My Primestar dishes have that same thing
Oh did I mention Keep it?![]()
Here's what I was going to try.Need a 3x4 multiswitch, and 2 Rx LNBOK...what you have there is a DirecPC/Direcway dish
These work very well with the dish. I have three of them all single polarities, I think. How do you tell if they will do both? Can they be set to do both? Two are single (one of each).
