Signal Amplification
illenema
7
Nevada
I am running a clear stream 2 outdoor antenna. Its connected to the DTVpal DVD.
I want to hook up a second converter to the antenna I think I wont have enough oomph to do it. Whats a good ampifier to use to split the signal and ampifiy. Looks like they are +15db The clear stream has a matching unit for the antenna but its 100$
Winegard HDP-269 should work.
Check to make sure you don't have any FM stations or TV stations within 5 miles - possible overloads with pre-amps.
I'd suggest that before you go out and blow dozens of dollars you see how it goes. What does the DTVPal report your signal strengths to be now?
Yes this might be a problem as lowest channel is about 58 highest 90. Also within 2 miles of a tv station.
The lowest channel just barley comes in at times. I should pry try additional hight on the antenna?
Two miles is awfully close to have to worry about anything but multipath.
An amplifier might make it worse.
Do not assume that you're going to have a problem.
They are right. You probably just need to realign your antenna. If you feel you need a booster, and you just may, I suggest this:
Signal Booster Store | Products | Motorola Cable TV Amplifers
Shop around for the best prices tho. I use the EXACT same thing but it is labeled as NexxTech. I got a rare deal. Brand new it was $7 shipped. You can find them time to time for $20. I am also 35+ miles from the towers though.
Samsung Model SIR-TS160 High Definition Receiver
Antenna ID help?
