Tilt off 2 degrees
Lem52
249
Cookeville, TN
I have had Directv for about a year. I just today looked on the dish at the tilt setting and its off by 2 degrees and is supposed to be set on 70 for my area. Should I put that directly on the 70 for the tilt? It was put there by the installer. I can post my signal levels when I have time.
Lem52
Lem52
As long as your signal levels are good, don't worry about where the dish is set. The installer likely adjusted it that way when it was installed.
He may have had to use that setting if the mast wasn't perfectly plumb.
I know the pole is plumb! I installed it myself. But as long as I get the picture as good as I have been getting it, maybe no reason to touch it. I was just wondering about it after I got to looking at the dish.
Lem52
Lem52
Did you have a chance to look at your signal levels?
Cookeville, Tenn in the heart of Middle Tennessee
Satellite 101
1-8 95-95-95-0-95-97-94-96
9-16 94-96-96-0-96-98-91-88
17-24 86-97-88-0-96-98-94-98
25-32 95-0-89-96-90-97-86-99
Satellite 99c
1-8 94-95-94-95-91-92-92-95
9-16 89-92-93-95-92-95-NA-NA
Satellite 99s
1-8 51-95-69-71-63-0-NA-NA
9-16 NA-NA-NA-NA-NA-NA-50-0
17-24 93-95- 0- 0- 0-25-37-21
25-32 NA-NA-NA-NA-NA-NA-NA-NA
Satellite 103s
1-8 0-0-0-0-0-0-NA-NA
9-16 NA-NA-NA-NA-NA-NA-74-62
17-24 67-23-0-67-80-83-77-0
Satellite 103ca
1-8 NA-NA-NA-NA-NA-NA-NA-NA
9-16 92-91-88-89-91-89-86-91
17-24 87-88-85-88-82-85-82-85
Satellite 103cb
1-8 94-91-92-89-92-88-91-88
9-16 92-85-91-85-92-86-NA-NA
17-24 NA-NA-NA-NA-NA-NA-NA-NA
Lem52
Satellite 101
Satellite 99c
Satellite 99s
Satellite 103s
Satellite 103ca
Satellite 103cb
Lem52
Those are good solid numbers. They could be a little higher, but you should be fine.
