AMC 6 @ 72W C-Band?
phlatwound
3,326
376
Goosapeak Junction
Is there any 24/7 DVB-S C-band signal on this bird?
I am trying to align and park my 7.5' Unimesh (don't presently have LOS or actuator range on my other BUDs) on 72W for some feeds and was looking for the PA Cable Network till I found out it has moved to 83W.
I know I am hitting the arc from 83W-121W, tried blind scanning in several spots looking for 72W but no luck so far.
I have a good sig on 3995/2220/v (caribbean network)
Thanks for that info, sj. I tried blind scanning, and manual scanning these 2 tps tonight with no results. I think I am just a little off the arc out at the ends.
I may try a little more tomorrow evening, if that doesn't work I'll cut a tree down so my BV solid can see 72W, it's been as far as 43W when the leaves are gone. :)
that bird is very weak for me on the 7 footer, I have never been able to get a DVB-S signal, most I've gotten is the baseball feed in analog from the Cardinals, which is usually broadcast on Sunday afternoon, that was how I located the bird
How about the old comeback, " Takes one to know one " !!, Stogie
Thanks Brent, quoted for truth! :D
That is the one I'm looking for, JohnP, I believe they also put up a DVB signal for those games, as well as the analog. If all else fails I will try hooking up an analog box to find it.
