Well, just received mine , here is what I find:
Well packed, brand new included was a HDMI 6' cable.
Got confuse when I noticed the power cord plug was different. You need to use an adpter suplied in the box. The plug and the adapter are very lose so I need to wrap both of them around with tape.
The unit I received came with the European factory File. So I couldn't proceed any further. After downloading several files (most of them didn't work at all) I found out HDS2_CM_america. This one worked perfect since I'm not using a motor and this one has the Diseqc 1.0 problems fixed. Also it loads the American sats from 43W to 139W. After finishing entering my sats configuration I begin to scan one at the time using the BLIND SCAN option. I was in shock!!!!! Tooked less than a minute to scan each sat including all the S2 signals. Unbeliavable!!! After finishing scanning al the sats I noticed so many more chanels than before. Even some with low quality that I can't watch before now are watchable w/out any pixls at all. Picture quality is very similar or better than my Coolsat 8000HD. The menu are different but they are really easy to get used to it. After I finished scanning my sats, I downloaded the DUMP_abs to my pen drive, load the it to my PC, use the editor to add the 3 CW's at Gal 17 91W, re-save back the file to my pen drive and re-load back to my Openbox. A very smooth and easy to do update:up. Now, I have everything working perfect including my CW's. As of right now, haven't play at al with the PVR function but this is going to be in a later review.
FORGOT TO MENTIONED VERY IMPORTANT THE BOX CAN DECODE THE AAC AUDIO!!!!!!!!!!!!!!!!!!!
Con's:
The Power Cord Plug Adapter to loose
Channel Editing/ rename/ Move or add to Fav is a little time consumption
Finally what in the word this people was thinking when they decided to put the USB connector in the real of the box!!!!!!!!! My TV is approx 6' 1/2 tall, So I need to use a ladder to reach the back any time I need to load/unload the USB pen drive!!!
So Overall this box is in a scale of 1-10 in 8. If they make the decision to add an OTA Tuner, move the USB connector to the front and fix the power cord conn issue wil be realy close to a 10!!!!!!!!!!!
Con's:
s)
