Another Coolsat 5k question
SATisfied
286
Lineboro, MD
I know that all the channels that appear in any channel list gets there by scanning the sat, but is it possible to just add a channel manually?
there is a trick. Iceberg showed me how to do it sometime ago. Make a search and look for it!!
There are 3 nets on 110 ku that won't scan in, and they are ITC....I have two of them. What I did was scan the tp, and it only gave me two scrambled channels. I then edited the pids and I got Fox and ABC. CBS is still available, but I don't have a third scrambled channel to edit the pids on. That's what I don't know how to do. How to get a third channel entered into that tp that I can then edit and get it, so to speak.
Channelmaster is the only way then
With the ones you are talking about the trick above wont work (just tried) ;)
You are limited to the # of channels the transponder scans in
Oh yeah....I almost forgot about Channelmaster....I've not tried it with the Coolsat yet. Thanks.
I downloaded CM and was able to add the new channel, although it took a little trial & error....my first attempt wiped out all my channels. I tried it again this time using the export wizard with the coolsat setting, and it worked perfectly. I was also able to move some of my sats that were out of order as well. Thanks for the tip!
Worst Use for a C-band Dish.....perhaps?????
TC-1000 and Stab HH 120
