Jeff from Mahattan has sent me over the latest firmware update for the Manhattan Receiver!
It should be noted that if you use this firmware it will wipe out all your channel information. (Basically it wipes everything out and you start from scratch) If you do not want to lose this info then you are advised to wait as there is supposed to be an upgrade coming which does not wipe everything out.
Here are the release notes I was sent:
Update List
Update List
1. Manual PID.
2. C/Ku universal LNBF settings.
3. Horizontal and Vertical Scanning.
Works in "fixed" mode. Does not work in "motor" mode
4. Up-load through USB. Which allows you to upload your scanned channels and changes made to you program list.
5. Un-lawful download. Will not allow bad files to be loaded onto the receiver.
6. DiSEqC 1.0 has been added.
Works in Fixed and "motor" settings. But not working in motor settings when USALS is selected.
7. DiSEqC 1.1 has been added.
8. Motor Drive movement works in DiSEqC, but only when you control in Horizontal or Vertical settings.
9. The USALS motor control still is being worked on. We are had some issues with this but the sw guys are working hard at it. We will have this done shortly, which will include all motor control.
10. Removal of games.
11. Addition of video format key on remote.
The receiver that I have has a res key. It only displays the resolution for HD signals.
12. Unicable for more than one receiver off one Unicable LNBF. Built in switching that allows the use on up to four receivers from one antenna and LNBF.
Pending Updates
1. Channel audio & video select will be changed. Depress the OK button twice to activate channel or satellite.
2. Black screen for audio.
3. Adding additional information to the "i" information key. FEC, S2, MPEG format, Pilot on/off, etc..
4. Motor drive movement.
Future updates will be available in the near future. If you have a suggestion for a feature, please send me an email.
I will also be posting this file in our file area for download shortly, but wanted to post it here as well so I could warn you and give you the release notes.
Update List
Update List
1. Manual PID.
Pending Updates
