Aiming SL3
Mikey11
858
16
canada
trying to aim a dish with the SL3 lnb on it....it seems this would be alot simpler if i could connect the center "eye" directly to my FTA receiver....is this possible? what type of switch is inside this lnb? is it diseqc controlled?
i realize my fta receiver will not "lock" the signal, but the meter will "bounce" up and down, verifying my aim, i have used this method before while aiming a single lnb DTV dish
Mikey it depends on the LNB. If its a non SWM (there are 4 outputs on it) 101 should work fine as the single LNB setup for aiming.
If its a SWM then you need a Directv receiver to do it
Do you not have a D* receiver? I'm confused as to what you're trying to do too.
An SL3 only has one "eye", if your dish has three then it's an SL5.
You align the dish on 101, so initially there's only one satellite to worry about. I see you are in Canada, so you might not see any of the other satellites at decent signal strength depending on where you are (where are you exactly?). If you are in an area where there is decent 101 signal, you should not have any trouble finding 101, using the receiver.
If it an SWM dish, however, you need the power inserter, and alignment is a bit more difficult
my apologies....i guess my description was not very good....it has 4 outputs....it is an SL3 lnb so only one "eye" but could i cover up the outer two portions of the one "eye", or connect directly to the center "eye" somehow, allowing me to aim the center "eye" at 101? this would seem like the easiest way to me....then all i would need to do is to fine tune the skew?
he has an H24 Direct TV receiver but i am not too familliar with these.....so it would be alot easier for me to aim the dish using an FTA receiver if possible, aiming the center "eye" at 101w
i want to hookup the center PORTION of the "eye" directly to my FTA receiver if possible
It's not that difficult to aim using the meters in the receiver. Give it a try!
not possible. and don't cover any part of the LNB array
but as mentioned its not hard at all using the actual DirecTV unit; just go grab a $12 heading compass (which no toolbox or glove compartment should be without). and using a 110% plumb/level mast and the proper coordinates, you should be good within 20 minutes
i am going to a customers house to aim this dish, i have never in my life operated a DTV receiver....any advice on what settings to look for in the menus?....i dont want to look like an A$$....i am very familiar with bell receivers and have aimed hundreds of dishes....do DTV receivers have signal meters similar to bell receivers?....aiming the dish will not be a problem, just want to know how to operate the receiver....lol
Signal meter is easy to find in setup menus. You want signal above 90. If HD, peak 101 then tweak 99/103 till all are 90+. 99/103 may require fine tuning, search youtube for slimline dithering for a video.
where do i find the signal meters in the menus?
do all 3 meters appear on the same screen? or do i need to check them one at a time?
also....this is for a DTV customer/subscriber who lives in the states....he has a second (summer) house here in canada which is where he wants this dish aimed from, i am assuming DTV signals are receivable here in canada?....about one hour north of toronto?
i have never aimed DTV before and dont want to look like an A$$hat
Once the receiver is on hit menu, find settings, then satellite, then signal strength.
The menu is a little different when the receiver is SFSS 771, but just look for dish pointing, or signal strength.
Do you know the az/elv and tilt yet?
If now use dishpointer.com
All three signals will not show at the same time, but once you have the 101 and 119 you'll be set
