AZ Fox S2S
wallyhts
Staff member
HERE TO HELP YOU!
3,219
448
The new kid in town from WSI.
AZ Fox S2S
MPEG4 DVB-S2 (High Definition HD) Free To Air C/Ku Band Direct To Home Satellite Receiver​
High-End digital receiver, with Blind Scan, USB DVR & HDMI Output,
Highlights
  • 1080P, 1080I, 720P, 480P, 480I format
  • USB DVR function
  • DiSEqC1.0/1.1/1.2 & USALS Motor Control
  • Aspect ratio adjustment 4:3 (16:9 crop), 4:3 (16:9 letterbox), 16:9 (4:3 pillar box)
  • User friendly OSD
  • Friendly user operation
  • Multi Language OSD
  • Parental control
  • Blind Scan
  • Zoom & pause function
  • Dolby Digital
  • Record one program, while watching another.​
  • Plays MP3 files, photos, etc.... via USB​
  • HDMI output​
  • Component video output​
  • Supports EPG
[TABLE="class: auto-style20, align: center"]
[TR]
[TD="class: auto-style23"]1. Tuner & Channel [/TD]
[TD="class: auto-style23"] 3. MPEG Transport Stream & A/V Decoding[/TD]
[/TR]
[TR]
[TD="class: auto-style21"] Type 1 ? F Type, IEC169-24, Female
Frequency Rage 950MHz to 2150MHz
RF Impedance 75 Ohm unbanlanced
Signal Level -65 to -25 dBm
LNB Power 13/18Vdc +/- 5%, 0.5Amax, Overload Protected
22KHz Tone Frequency :224KHz +/- 2KHz, 0.6Vpp +/- 0.2V
DiSEqC Control Version1.0, 1.2, Tone burst A/B
Demodulation QPSK, 8PSK
Input Symbol Rate DVB-S QPSK : 1~45 Msps
DVB-S2 8PSK/QPSK : 10~30Msps
FEC Decoder 1/2, 2/3, 3/4, 3/5, 4/5, 5/6, 8/9, 9/10 in DVB-S2 mode. 1/2, 2/3, 3/4, 5/6 and 7/8 in DVB-S mode.
[/TD]
[TD="class: auto-style21"] Transport Stream 13818-1 MPEG-2, H.264/AVC Transport stream Specification
Profile Level MPEG-2 MP@ML, MP@HL, MPEG-4 H.264/AVC
Input Rate Max. 90Mbit/s
Aspect Ratio 4:3, 16:9, Letter Box
Frame Rate 25Hz for PAL, 30Hz for NTSC
Video Resolution 576i, 576p, 720p, 1080i ,1080P
Teletext Through VBI
Audio Decoding MPEG-1 Layer 1 & 2, Dolby Downmix
Audio Mode Single Channel/Dual Channel Joint Stereo/Stereo
Frequency Response 20~20kHz, <+/-2dB
[/TD]
[/TR]
[TR]
[TD="class: auto-style23"] 2. System & Memory[/TD]
[TD="class: auto-style23"] 4. A/V & Date In/Out[/TD]
[/TR]
[TR]
[TD="class: auto-style21"] Main Processor ALI3601S
Flash Memory 4Mbytes
DDR II Memory 512Mbytes
Channel Capacity Digital Channel: 4,000
Front 1-Key(Power), 7-SEGMENT DISPLAY
[/TD]
[TD="class: auto-style21"] HDMI HD Video/Audio Output
Data Interface - RS-232, Bit Rate: 115,200baud
Connector: 9-pin D-sub Male type
- USB : USB 2.0, Type A Connector,
[/TD]
[/TR]
[TR]
[TD="class: auto-style23"] 5. Power Supply[/TD]
[TD="class: auto-style23"] 6. Physical Specification[/TD]
[/TR]
[TR]
[TD="class: auto-style21"] Input Voltage AC 100V ~ 240V, 50Hz ~ 60Hz
Power AC 100V ~ 240V
[/TD]
[TD="class: auto-style21"] Size(WxHxD): 7X9.5X2 Inches
Weight: Net Weight - 2.2lbs / Gross Weight - 2.4lbs
[/TD]
[/TR]
[TR]
[TD="class: auto-style23"] 5. Enviromental Condition[/TD]
[TD="class: auto-style24"] [/TD]
[/TR]
[TR]
[TD="class: auto-style21"] Operating Temperature 0 °C - 40 °C
Storage Temperature -10 °C - 50 °C
Operating Humidity Range 10~85% RH, Non-condensing
Storage Humidity Range 5~90% RH, Non-condensing
[/TD]
[/TR]
[/TABLE]
While it looks it has the AZ Box logo, I do not believe that the box is an actual AZbox.
Yup its the AZ Fox lol.
Hopefully I will have one by Friday to post pics videos etc...
You think they would have learned after the DMS lawsuit a few years ago.
Believe me, I am not saying anything bad about the receiver itself, the specs make it look like a fine receiver. I am only talking about the name of it, which is where I have an issue.
No disrespect to any site members who are associated w/ WSI here but I wouldnt touch any of their products with a 30 foot pole.
Cheers, K
Cheers, K
LOL not even a 10 foot pole went right for the 30 footer.
Did you get some bad WSI products?
so after you get it are you going to be Dr Seuss and say
The az fox rocks my socks or
the az fox is like a box of rocks
:D
@ Wally--> Got burned once yes. Apparently they admited their 69$ prime dish was sub-standard/defective which was something they neglected to tell me when I initially bought one.
Cheers, K
Cheers, K
Yup they are POS's. Thats why they were dumping them so cheap.
Yeah they were crappy dishes, but I still feel it was worth it for $69. The way I saw it if someone got one and tried it they would either love C Band or hate it. Hopefully those who love C Band went out and purchased a better dish now. :)
ANOTHER Ali box? Wow. Is anyone keeping track of how many of these things there are now? Why doesn't Ali just sell evaluation boards and SDKs to the general public and cut out the middlemen?
Because they would not have a closed source distro anymore.
I agree I would love to have the pinouts of the Ali chips and the sample design. You could add ports to the hardware you own if the product is lacking what you need.
Is the software/firmware significantly more stable than the AzBox? The Azbox is nice but the channel data is too easily corrupted.
Not even related to AzBox.
Az Fox is a IKS box from the South American market that was produced to play off the popularity of the AzBox name in the theft of services game.
AMC21 PBS Set up
SA PowerVu Receiver
