- Apr 24, 2008
- 3,219
- 448
The new kid in town from WSI.
[TABLE="class: auto-style20, align: center"]
[TR]
[TD="class: auto-style23"]1. Tuner & Channel [/TD]
[TD="class: auto-style23"] 3. MPEG Transport Stream & A/V Decoding[/TD]
[/TR]
[TR]
[TD="class: auto-style21"] Type 1 ? F Type, IEC169-24, Female
Frequency Rage 950MHz to 2150MHz
RF Impedance 75 Ohm unbanlanced
Signal Level -65 to -25 dBm
LNB Power 13/18Vdc +/- 5%, 0.5Amax, Overload Protected
22KHz Tone Frequency :224KHz +/- 2KHz, 0.6Vpp +/- 0.2V
DiSEqC Control Version1.0, 1.2, Tone burst A/B
Demodulation QPSK, 8PSK
Input Symbol Rate DVB-S QPSK : 1~45 Msps
DVB-S2 8PSK/QPSK : 10~30Msps
FEC Decoder 1/2, 2/3, 3/4, 3/5, 4/5, 5/6, 8/9, 9/10 in DVB-S2 mode. 1/2, 2/3, 3/4, 5/6 and 7/8 in DVB-S mode. [/TD]
[TD="class: auto-style21"] Transport Stream 13818-1 MPEG-2, H.264/AVC Transport stream Specification
Profile Level MPEG-2 MP@ML, MP@HL, MPEG-4 H.264/AVC
Input Rate Max. 90Mbit/s
Aspect Ratio 4:3, 16:9, Letter Box
Frame Rate 25Hz for PAL, 30Hz for NTSC
Video Resolution 576i, 576p, 720p, 1080i ,1080P
Teletext Through VBI
Audio Decoding MPEG-1 Layer 1 & 2, Dolby Downmix
Audio Mode Single Channel/Dual Channel Joint Stereo/Stereo
Frequency Response 20~20kHz, <+/-2dB
[/TD]
[/TR]
[TR]
[TD="class: auto-style23"] 2. System & Memory[/TD]
[TD="class: auto-style23"] 4. A/V & Date In/Out[/TD]
[/TR]
[TR]
[TD="class: auto-style21"] Main Processor ALI3601S
Flash Memory 4Mbytes
DDR II Memory 512Mbytes
Channel Capacity Digital Channel: 4,000
Front 1-Key(Power), 7-SEGMENT DISPLAY[/TD]
[TD="class: auto-style21"] HDMI HD Video/Audio Output
Data Interface - RS-232, Bit Rate: 115,200baud
Connector: 9-pin D-sub Male type
- USB : USB 2.0, Type A Connector, [/TD]
[/TR]
[TR]
[TD="class: auto-style23"] 5. Power Supply[/TD]
[TD="class: auto-style23"] 6. Physical Specification[/TD]
[/TR]
[TR]
[TD="class: auto-style21"] Input Voltage AC 100V ~ 240V, 50Hz ~ 60Hz
Power AC 100V ~ 240V[/TD]
[TD="class: auto-style21"] Size(WxHxD): 7X9.5X2 Inches
Weight: Net Weight - 2.2lbs / Gross Weight - 2.4lbs[/TD]
[/TR]
[TR]
[TD="class: auto-style23"] 5. Enviromental Condition[/TD]
[TD="class: auto-style24"] [/TD]
[/TR]
[TR]
[TD="class: auto-style21"] Operating Temperature 0 °C - 40 °C
Storage Temperature -10 °C - 50 °C
Operating Humidity Range 10~85% RH, Non-condensing
Storage Humidity Range 5~90% RH, Non-condensing [/TD]
[/TR]
[/TABLE]
AZ Fox S2S
MPEG4 DVB-S2 (High Definition HD) Free To Air C/Ku Band Direct To Home Satellite Receiver
High-End digital receiver, with Blind Scan, USB DVR & HDMI Output,
Highlights
Highlights
- 1080P, 1080I, 720P, 480P, 480I format
- USB DVR function
- DiSEqC1.0/1.1/1.2 & USALS Motor Control
- Aspect ratio adjustment 4:3 (16:9 crop), 4:3 (16:9 letterbox), 16:9 (4:3 pillar box)
- User friendly OSD
- Friendly user operation
- Multi Language OSD
- Parental control
- Blind Scan
- Zoom & pause function
- Dolby Digital
- Record one program, while watching another.
- Plays MP3 files, photos, etc.... via USB
- HDMI output
- Component video output
- Supports EPG
[TR]
[/TR]
[TR]
[/TD]
[/TR]
[TR]
[/TR]
[TR]
[/TR]
[TR]
[/TR]
[TR]
[/TR]
[TR]
[/TR]
[TR]
[/TR]
[/TABLE]
