- Apr 24, 2008
- 3,218
- 442
The new kid in town from WSI.
AZ Fox S2S
MPEG4 DVB-S2 (High Definition HD) Free To Air C/Ku Band Direct To Home Satellite Receiver
High-End digital receiver, with Blind Scan, USB DVR & HDMI Output,
Highlights
Highlights
- 1080P, 1080I, 720P, 480P, 480I format
- USB DVR function
- DiSEqC1.0/1.1/1.2 & USALS Motor Control
- Aspect ratio adjustment 4:3 (16:9 crop), 4:3 (16:9 letterbox), 16:9 (4:3 pillar box)
- User friendly OSD
- Friendly user operation
- Multi Language OSD
- Parental control
- Blind Scan
- Zoom & pause function
- Dolby Digital
- Record one program, while watching another.
- Plays MP3 files, photos, etc.... via USB
- HDMI output
- Component video output
- Supports EPG
1. Tuner & Channel | 3. MPEG Transport Stream & A/V Decoding |
Type 1 ? F Type, IEC169-24, Female Frequency Rage 950MHz to 2150MHz RF Impedance 75 Ohm unbanlanced Signal Level -65 to -25 dBm LNB Power 13/18Vdc +/- 5%, 0.5Amax, Overload Protected 22KHz Tone Frequency :224KHz +/- 2KHz, 0.6Vpp +/- 0.2V DiSEqC Control Version1.0, 1.2, Tone burst A/B Demodulation QPSK, 8PSK Input Symbol Rate DVB-S QPSK : 1~45 Msps DVB-S2 8PSK/QPSK : 10~30Msps FEC Decoder 1/2, 2/3, 3/4, 3/5, 4/5, 5/6, 8/9, 9/10 in DVB-S2 mode. 1/2, 2/3, 3/4, 5/6 and 7/8 in DVB-S mode. | Transport Stream 13818-1 MPEG-2, H.264/AVC Transport stream Specification Profile Level MPEG-2 MP@ML, MP@HL, MPEG-4 H.264/AVC Input Rate Max. 90Mbit/s Aspect Ratio 4:3, 16:9, Letter Box Frame Rate 25Hz for PAL, 30Hz for NTSC Video Resolution 576i, 576p, 720p, 1080i ,1080P Teletext Through VBI Audio Decoding MPEG-1 Layer 1 & 2, Dolby Downmix Audio Mode Single Channel/Dual Channel Joint Stereo/Stereo Frequency Response 20~20kHz, <+/-2dB |
2. System & Memory | 4. A/V & Date In/Out |
Main Processor ALI3601S Flash Memory 4Mbytes DDR II Memory 512Mbytes Channel Capacity Digital Channel: 4,000 Front 1-Key(Power), 7-SEGMENT DISPLAY | HDMI HD Video/Audio Output Data Interface - RS-232, Bit Rate: 115,200baud Connector: 9-pin D-sub Male type - USB : USB 2.0, Type A Connector, |
5. Power Supply | 6. Physical Specification |
Input Voltage AC 100V ~ 240V, 50Hz ~ 60Hz Power AC 100V ~ 240V | Size(WxHxD): 7X9.5X2 Inches Weight: Net Weight - 2.2lbs / Gross Weight - 2.4lbs |
5. Enviromental Condition | |
Operating Temperature 0 °C - 40 °C Storage Temperature -10 °C - 50 °C Operating Humidity Range 10~85% RH, Non-condensing Storage Humidity Range 5~90% RH, Non-condensing |
