Hi,
I have a question for the gurus.
Currently I have a G-box to move my 10 foot dish. But I also have an Eagle Aspen OTA antenna rotator which seems to be a clone of the G-box. They look physically different from each other however the remote controls are almost identical with the exception of the EA missing a few buttons. I can use the remotes interchangeably and much to my annoyance, when I want to operate one, both respond and things go bonkers and make trouble for me.
I end up having to put several layers of heavy black cloth over one or the other depending on which one I need to operate.
So now I've been looking at the ASC1 to replace the G-box (which I plan to reuse on a different, future project).
I understand that it will operate the polarity motor in an LNBF and I think that's really cool because it's sooooooo annoying trying to get an LNBF set right. With that, you can adjust it from inside in the A/C.
But what I am unclear on is can I also use it with the more modern 13/18 type LNBFs that are so common now? At some future time I might like to get a high quality LNBF with motorized polarity but for the immediate future I'm stuck using the 13/18v types.
Can the ASC1 work with either type? Or is it only able to operate one that is motorized?
Can the ASC1 work with this type of LNBF?
Or is it limited to only working with this type?
Or will it work with either type?
I'm thinking if it will work with something like a CW2PLL then I could put the ASC1 and a HH USALS all on my Amiko A3.
Thanks..
Thanks..
