If I'm repeating a previous thread I apologize. My question is simple. Can the mini genie be taken and used in an rv? The main receiver needs to stay at the house.
Thank you
Thank you
Thank you
Without the genie (server) the mini genie (client) is a very ineffective paperweight. It must be within the same coax network as the genie to function.[/QUOTE
Thank you. So what are my alternatives? Any suggestions would be greatly appreciated.
I actually have a slim line dish for it. I just need to figure out how to get service to the rv on the same account if possible.as far as i know, directv does not do rv installs
if you have a dish currently, you can contact someone like solid signal to see what will work with it
or look for a local retailer
to Satelliteguys Tazfire!Technically, but no one cares about that.technically the account is only supposed to be viewed in one place at a time, home or the rv
and that is why i said technicallyTechnically, but no one cares about that.
Who's to say that it would be viewed in more than one place at a time ?technically the account is only supposed to be viewed in one place at a time, home or the rv
I would see if Directv will drop ship you an additional receiver, best if it's an H24 since it doesn't need to be on a swm system like the H25 does. Tell us about your system. It's a swm type since you have a Genie, but do you know what model lnb you have? That's the device at the end of the arm of the dish. What other boxes do you have in your house? There are limits to how many you can have with certain lnbs, so if you go over that theoretical limit, Directv won't just send you another one.
A gen 2? It's the new HR17?Chip,
The lnb is a SL5. The rest of the current system is the Genie Gen 2 with three minis. DIRECTV did agree to send me a standard HD receiver with free installation which as you know I don't need.
That is what you need. Connect it into your system and get it authorized, then move it to the rv. One caveat, you should have the same swm type setup in the rv in case you want to move the receiver back to the house. It will make the process simpler.
