Help with Cobaltfhd
navagator
SatelliteGuys Guru
142
26
I'd like to try the Cobaltfhd skin on my OS Mio 4K but for some reason it won't install. I've deleted all skins except for the Pli skin and a skin named Emergency which I can't find a way to uninstall.
I must be doing something wrong, does anyone have any suggestions?
Some skins are not built to be compatible with all images or versions. Have you tried installing the skin on a different image? Be careful! Incompatible skins can cause serious problems.
You might check with the skin's author for compatibility questions.
What does "won't install" mean? Are you using the IPK file? What image are you trying to install it on? Did you make a FULL backup beforehand? As Brian said, a skin can cause some serious problems, if not tweaked specifically for the image you are running.
That skin supposedly works with regular OpenPli image. I highly suggest you load OpenPli in one of your slots, and see if that skin wil then load on THAT image.
Thank you for your reply.
I tried installing it on TNAP 3.2. I went to the plugins menu and selected the skin there and a black box came up that basically said "no packages installed or removed". I do have a full backup, I know the importance of that. Maybe I will load OpenPli and try that as you suggested.
Locked up OS MIO 4K
Dreambox Edit Question
