New OTA Antenna Installation - Winegard YA7000C Review
spongella
1,625
1,236
Central NJ
A Winegard YA7000C VHF/UHF yagi plus a Winegard BoostXT preamp (18 dB) were erected yesterday at the home QTH. I wanted something to pick up low VHF TV (54 - 88 MHz) channels and this antenna has low VHF elements, plus high VHF (174 - 216 mHz) and UHF. Due to the recent snow I erected it temporarily outside on a 12 foot pole and pointed it SE for Philadelphia stations. Philly's about 35 miles away, NYC about 50 miles. A total of 74 channels were received, mostly from Philly. Also received two NYC stations and several from NJ. So the range is from 35 - 50 miles. A rotor and increased height would definitely bring in more stations but it's not priority at the moment. My STB is a Mediasonic Homeworx converter box which I was using prior to the new antenna installation.
Yagi is 34.5 inches long, longest element is 100" (for low VHF). Weight is about 5 lbs, easy to erect. Very well constructed as was expected with all Winegard products. Amazon price was $117 with the preamp. Winegard site is selling this antenna for about $55 with free shipping, less than Amazon. Definitely satisfied with this installation. Thanks for reading and Merry Christmas.
Reactions: madmadworld
How does low-VHF reception compare against other antennas you've tried? I've seen the YA7000C previously and was wondering about that.
- Trip
Reactions: spongella
- Trip
Well, prior to this antenna I was using one of those "150 mile" antennas that are cheap and have a rotor built in. It worked well on UHF but not as well on VHF as the Winegard. Winegard's much much better.
I hooked up the YA7000 and preamp to my HP spectrum analyzer. If you look at the attachment, you can see a spectral scan of the low VHF (54 - 88 mHz) TV band.
There are three major 6 mHz-wide peaks. To the left is WDPN TV, Channel 2, 54 - 60 mHz, from Delaware with a good signal.
Center peak is Channel WACP-TV, 66 - 72 megs, from Atlantic City.
Right peak is WPVI TV, Channel 6, 82 - 88 megs, from Philly.
All come in with no pixelation. So far, so good as far as I can tell.
Merry Christmas to all.
If you are picking up Channel 6 from Philly, you are doing very well. I may have to look at this antenna to replace my CM 4221 which receives UHF and some VHF-Hi.
Looks like one carrier is about 30dB C/N, one is about 25dB and the worst is maybe 20dB, huge signals overall.
WMYD (RF31) Detroit brings ATSC 3.0 to the metro Detroit area.
WTCI PBS Chattanooga TN adds .4 subchannel
