satellite switch 8 ports with universal LNBs
ken2400
1,309
144
Central NY State
I want to connect more than 4 LNBs to a satellite receiver BUT I seem to recall that I can not do it using universal LNBs?
I am remembering wrong?
you are remembering right and wrong... what you cannot use are the 22KHz switches, since there's already one in the universal LNBF. So you can't stack a 4-port diseqc with 22kHz switches if the LNB(F)s are universal.
However, you can use an 8-port diseqc 1.1 switch, works great! I'm using one with several universal LNBFs without any problem
I'm using the GeoSatPro 8-port switch. I also have a Pansat 8-port but had a few problems with that one (minor problem)
I use an 8-port switch and it has always worked for me.
Found Globecast receiver model SE830-T0N9-S
LPB on 87W?
