Weird audio performance
WhiteBeard
Arrgh!
18,447
14,329
USA
Is it just me or is there some kind of audio problem? Doesn't matter if it's via satellite or streaming - the audio tends to drop off on occasion.
Reactions: Howard Simmons
I've got the old Delphi home kit and I listen to 60's on 6 in the afternoon and every so often the volume goes up then back down where it was. So I think it might be in the system.
I very rarely notice that happening either in my car or streaming. But I do notice it. What channel? How often?
I listen to 80's on 8 most of the time when traveling. My Xterra head unit has an integrated SXM receiver but I stream in the Mustang using a type C to HDMI configuration from the smartphone to the head unit. Sometimes I listen on the PC but not nearly as often.
The Mustang head has HDMI in? :imconfused
Some aftermarket head units do have HDMI but not my Pioneer in my 2002 Mustang. I use an HDMI to RCA converter to connect to the AUX IN port. I thought my wiring had a problem until I heard the same thing happening on the Xterra satellite receiver.
  • Wow
Reactions: TheKrell
I noticed that Classic Vinyl was having some pretty serious problems yesterday with dropouts and volume level changes. It wasn't evident on Classic Rewind so I spent the rest of the day there.
I can't explain the issue but I can confirm that there was an issue with the incoming side of Sirius (since it impacted both satellite and streaming).
I mainly listen via app on AppleTv or Roku, depending on room. I think I've experienced this two or three times over the last month.
SiriusXM OEM car radio antenna problems - alternate solution question
Any Dead Heads out there?
