New pc build.
John2021
1,552
830
Los angeles
I just built a new pc specs are as follows
corsair 500D airflow case
Asus ROG maximus Z790 hero motherboard
intel core i9-14900k oc to 8GHZ
Corsair dominator titanium RGB DDR-5 OC to 7000 MHz
Corsair HXI 1500 psu
samsung 9100 4 TB pro m.2
Corsair icue link H100i lcd liquid cpu cooler
4 corsair QX rgb fans
Corsair ram lighting enhancement sticks
Asus rtx 5090 astral gpu oc edtion
  • Love
Reactions: HipKat
I would have probably stayed away from Intel, but looks pretty good regardless. 8ghz, wow.
I got so burnt on my last build (5800x, RTX 3090), airflow w/ the 3090 was a nightmare and even once I went to a water cooled 4090 (and yolo'd a 5950x upgrade too... because.. uh.. I might stream so extra threads??) I still had issues. Turned out an AIO I had on my CPU was somehow overheating and triggering a shutdown. After all this I'm not sure I'll build a high end PC again, almost want that reassurance of a pre-build, so I have someone else to blame for doing it poorly.
Really need to cobble some parts together so the kids have a low-end PC for productivity / light gaming (son has been using my Steam Deck, everyone else sticks to their consoles). A project for the summer... which will be here in a couple months I suppose. Blah.
How much did you spend on this?
I'm itching to do a new build, myself
corsair 5000d case was 119.99
corsair hxi psu was 349.99
corsair icue link H100i liquid cpu cooler 184.99
corsair icue link RGB 120 QX fans 3 starter pack 159.99
corsair one single QX rgb fan 49.99
samsung 9100 pro 4TB drive 549.99
ASUS rog maximus z790 mother board 549.99
i9 14900k cpu 479.99
corsair dominator titanium ddr 5 ram 200.00
corsair ram lighting effect sticks 60.00 id'e say
ASUS ROG astral 5090 OC gpu 3,200.00
total 5,904.92
Reactions: meStevo and HipKat
total 5,904.92
That's about what I spent on my last one and would figure to spend again on a new one.
Killer system there
after running it for a while i wanted performance and not to dated like on some of the budget builds
I get that, but you've got some elements in there like the 4TB m.2 drive that are wicked expensive, and I'm having a hard time imagining why you need that large of a high-speed drive.
In the grand scheme, Microsoft usually figures out a way to hobble even the most insane hardware (this has been a problem on both the Intel and AMD side).
Reactions: John2021 and HipKat
did you ever get the new build going yet???
No, I'm updating, instead. The motherboard, Case, and power supply are all great. I updated my RAM from 32GB of DDR4 2166 to 64GB DDR4 3600 and moved my Windows to a new 2TB M.2 drive and my Archlinux to a new 1TB M.2 Drive.
Next update will be moving from a 3060TI to a 4080 GPU.
If I ever feel like I need to move to DDR5 RAM, I'll invest in a new board but I'm solid right now and the GPU upgrade will be a big step.
Reactions: John2021
I'm a bit leery of Nvidia high end GPU's. I keep updated on Nortwest Repair, Northridge Fix, and a few others on YouTube. All the same. Fried power connectors. Tendency to crack where the main board connector latch is on them.
A bit scary. Companies ditching warranties and just reflowing the core when they do honor them. Power connector repair denied due to claims of incorrect PSU plug connection.
But man! Talk about keeping up with the Joneses! You really get immersed in games.
As for "dirt cheap". After seeing a few clips showing too good to believe Nvidia 40XX and 50XX GPU's with missing cores and ram. Or fake ram swapped out. Scary.
At the least go for a Square Trade plan.
I'm a longtime Asus fan for pc builds. But as of late they scare me. Laptops, GPU's and mainboard failures.
Not being negative. Just aware. Very aware!
  • Sad
Reactions: navychop
You have to be very careful on counterfeit GPU's. Amazon, New Egg, etc are flooded with them
Reactions: John2021
True i picked the 4 TB drive since i have alot of games on it
as far as the M.2 drive i do alot of video rendering in 4k!!! i would not last with a 1 or 2 TB drive LOL. gen 5 drives are amazing for video rendering and it helps while gaming belive it or not!!! since the speed depends on there servers the bandwith there sending you... i have more than one game downloaded to me pc plus alot of viseos to edit.. what do you mean by hobble??? slow the system down??? thats microsofts updates. i wipe my pc every 1-2 years to make it speedy again. going from a gen 4 system to a gen 5 system is like night and day though. most wouldn't need a pc of my spec... another issue is since it's OC so hard it becomes a space heater!!!
Reactions: HipKat
what 4080 are you going with asus has monitoring software so it don't burn the house down LOL!!!
Probably highly suggested to install the GPU with case on it's side so plug it in vertically.
And take every precaution to add supports if at all possible.
  • Wow
Reactions: Foxbat
I'm not sure. The 3060TI is a Zotac. Not really sure where I stand with it. I'll be doing some looking around when the time comes. My GF and I dropped money on a new Glass Top/Convection oven and a bigger refrigerator.
Windows 10/11 Download
